Activity › Forums › Adobe After Effects › Reversing the Stroking of a Path
  • Reversing the Stroking of a Path
    Posted by Ed Hecht on March 24, 2009 at 11:44 pm
    Apologies as I am sure it’s been gone over countless times. I have several paths that need to be stroked out from one central origin point. I created all the paths previously-some seemingly from the destination point back to the point of origin. No matter what I do in the Start and End values in the Stroke effect, the path always starts at the destination point. Assuming this is tied to the order the points were created, is there no way to reverse/change the destination/origin points AFTER the fact? The paths I have are fairly complex and would like to avoid recreating them. TIA!
    Todd Kopriva replied 17 years, 6 months ago 4 Members · 3 Replies
  • Filip Vandueren
    March 25, 2009 at 1:36 am
    You can animate some strokes in reverse (make a copy of the layer and keep the OK strokes separate):
    https://forums.creativecow.net/thread/2/843771
    or
    I would convert the paths to shapes using:
    https://www.redefinery.com/ae/view.php?item=rd_MasksToShapes
    In shape layers, there’s a trim path function that will do the same as an animated stroke, and every single shape bezier curve has it’s own reverse path button.
    + as an added bonus the end result is vector crispy, and has other stuff you can’t do with strokes
  • John Cao
    March 25, 2009 at 1:41 am
    Or you can precomp your stoke animaion and apply time remapping
  • Todd Kopriva
    March 28, 2009 at 6:54 am
    You can directly reverse the direction of a shape path. There’s a pair of buttons (Reverse Path Direction On and Reverse Path Direction Off) next to the Path property in the Timeline panel.
    And stroking shapes is much more versatile than stroking masks.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
