Activity › Forums › Apple Final Cut Pro Legacy › reversing telecine
  • Jeremy Garchow
    July 31, 2009 at 7:39 pm
    DId you drag the setting on to the job?
  • Matthew Sonnenfeld
    July 31, 2009 at 7:46 pm
    Yeah I did. Problem?
    Panasonic HPX170 P
    Unibody Macbook Pro 15 inch, 2.8 Ghz, 4GB RAM
    Final Cut Pro Studio 2
    Avid Media Composer
    The College of WIlliam and Mary
  • Jeremy Garchow
    July 31, 2009 at 7:57 pm
    No, not a probelm, it’s what you should do. Something sounds incorrect in your setup.
    July 31, 2009 at 8:08 pm
    here is my inspector information. do you see any problems?
    Name: Reverse Telecine of 3:2 Pulldown
    Description: Apple ProRes 422 video with audio pass-through. Settings based off the source resolution and frame-rate.
    File Extension: mov
    Estimated file size: 1.13 GB
    Audio: multi-track passthrough
    Video Encoder
    Format: QT
    Width: (100% of source)
    Height: (100% of source)
    Selected: 1280 x 1080
    Pixel aspect ratio: DVCPRO HD 1080i (16:9)
    Crop: None
    Padding: None
    Frame rate: 23.976
    Frame Controls On:
    Retiming: (Fast) Nearest Frame
    Resize Filter: Linear Filter
    Deinterlace Filter: Reverse Telecine
    Adaptive Details: Off
    Antialias: 0
    Detail Level: 0
    Field Output: Progressive
    Codec Type: Apple ProRes 422 (HQ)
    Multi-pass: Off, frame reorder: Off
    Progressive
    Chroma filtering enabled
    Pixel depth: 24
    Spatial quality: 50
    Min. Spatial quality: 0
    Temporal quality: 0
    Min. temporal quality: 0
    Panasonic HPX170 P
    Avid Media Composer
  • Jeremy Garchow
    July 31, 2009 at 8:12 pm
    Yes, if you are going to ProRes HQ from DVCPro HD youshoudl make the frame size 1920×1080 and not 1280×1080.
    Jeremy
    July 31, 2009 at 8:19 pm
    Great catch! and i also just found something interesting. in the bottom left of the main window, it said 1 Job, 2 Targets. When I deleted the destination it said that it was back to 1 Job, 1 Target and will now let me submit the clip. However, will that mean that I will replace my originals? I have all of the footage backed up on multiple drives so I would be able to transfer it over again if I needed to. What do you think?
    I should just be able to reconnect back to the new media that compressor makes without a problem right?
    Panasonic HPX170 P
    Avid Media Composer
  • Jeremy Garchow
    July 31, 2009 at 8:27 pm
    [Matthew Sonnenfeld] “I should just be able to reconnect back to the new media that compressor makes without a problem right? “
    No as you have a new frame rate. Did the file name have a warning sign on it? If the file name matches the name in the capture scratch excatly, it will over write.
    Jeremy
    July 31, 2009 at 8:41 pm
    No, the file does not have a warning sign on it. Should I just go ahead and submit and see how it goes?
    Panasonic HPX170 P
    Avid Media Composer
    July 31, 2009 at 9:00 pm
    Okay so I went ahead and gave it a go. The new footage looks to be perfect and it did not replace the old clip so I’m going to go ahead and try the rest of them. Thanks for all of your help!
    Panasonic HPX170 P
    Avid Media Composer
  • Jeremy Garchow
    August 1, 2009 at 3:19 am
    No worries.
    Jeremy
Page 2 of 2
