Activity Forums Maxon Cinema 4D reversing particle emitter
  • reversing particle emitter
    Posted by Sarah Womack on March 6, 2013 at 11:32 pm
    hey
    Im currently in the process of making confetti burst into a scene and I need to know if it is possible to freeze the emitter in mid explosion and then reverse it?
    thanks
    Sarah
    Sarah Womack replied 13 years, 6 months ago 4 Members · 8 Replies
  • 8 Replies
  • Tim Shetz
    March 7, 2013 at 12:05 am
    That sounds like something I would do in After Effects if possible.
    __________
    Tim Shetz
    c4dtraining.com
  • Sarah Womack
    March 7, 2013 at 12:54 am
    thanks for the reply!
    it needs to be done in cinema 4D so I was thinking someone must know if it is possible :/
    After effects probably does do it but my project for uni is entirely in cinema 4D
  • Tim Shetz
    March 7, 2013 at 4:04 am
    Sorry, what I meant was render it off from Cinema 4D and then take the footage into After Effects to reverse the section I needed. I almost always take my renders from Cinema into After Effects to do some color correction/adjustment or add some things that I can’t or don’t want to do in Cinema.
    Not enough coffee when I answered…
    Are you using just the regular emitter, or thinking particles?
    __________
    Tim Shetz
    c4dtraining.com
  • Sarah Womack
    March 7, 2013 at 1:52 pm
    I cant use after effects really becuase I have a camera moving around a 3D city and the confetti will be falling while the camera is pointing to the sky and spinning around so the after effects wont be efficient enough to look real if you know what I mean.
    heres the animation I am currently working on…
    https://www.youtube.com/watch?v=STD6oaEdvaY
    from 1.21 is where I am wanting the confetti to fall, freeze and then at 1.27 reverse
    thanks
  • Tim Shetz
    March 8, 2013 at 5:00 am
    So will you be using the regular emitter or thinking particles?
    I can’t think of any way to freeze and reverse the regular particles without rendering them separately and then compositing them back in.
    As far as thinking particles go, I’m not an expert…so there might be a way with them.
    Is this ultimately going to be rendered as a quicktime or some other format?
    __________
    Tim Shetz
    c4dtraining.com
  • Craig Whitaker
    March 11, 2013 at 4:09 pm
    Check out the plugin TP Partio. It enables caching of TP which then enables reverse, hold, etc.
    Best,
    Craig
    Craig Whitaker
    Digital Design Director
    Assembly
    161 Leverington Avenue Suite 1002
    Philadelphia, PA 19127
    O: 215-487-2060
    craig@assemblypix.com
  • Brian Jones
    March 11, 2013 at 6:31 pm
    yeah, or pCache
  • Sarah Womack
    March 11, 2013 at 6:36 pm
    thanks gonna check both out!
    Ill get back to ya and let you know how it went.
