Activity Forums Maxon Cinema 4D Reversing keyframe sequences
  • Reversing keyframe sequences
    Posted by Stu Pond on April 27, 2005 at 1:46 pm
    Anyone know of a quick method of reversing a sequence of keyframes without dragging each one individually?
    I need to reverse a sequence with several tracks on different objects, but cannot seem to find a way in the timeline.
    Stu
    John Paterson replied 16 years, 1 month ago 3 Members · 3 Replies
  • Joe Bird
    April 28, 2005 at 5:11 pm
    Heres a method: go to F-curves, drag in the objects to be reversed, select all (make certain they are all highlighted) then go to curves/ mirror X, ( it seems like Y would be the correct choice, but X works for me)
    I bet there’s an easier way to do this, there are some really useful keyframe plug-ins out there, like offset and timeline tools…
    Let us know if you find an easier way..
    best regards
    Bear
  • Stu Pond
    April 29, 2005 at 8:51 am
    Cheers Bear!
    Works a treat (but not on PLA for some reason).
    There must be a more simple way, but the C4D manual is possibly the worst in the world in my opinion, so I’m going to0 keep looking.
    Stu
  • John Paterson
    July 14, 2010 at 7:32 am
    The easiest way is to select all the keyframes in the timeline view then select Functions>Move/Scale and enter a value of -1.
    This reverses the frames but you will have to move them further up the timeline as this reverses about the start of the sequence.
