Activity Forums Adobe After Effects Reversing field order / dominance
  • Reversing field order / dominance
    Posted by Martin Fisher on July 28, 2010 at 11:54 am
    Hi there,
    Hope that someone can clarify this ASAP (as i have to render things tonight for deliver them tomorrow)
    I need to reverse the field order of a footage that im working with. This footage was shot on XDCAM. Its HD (1920×1080) 29.97 fps Upper field first. This needs to be outputed on a DigiBetacam NTSC (720×480) 29.97 Lower field first.
    1.So, the editor send me a QuickTime movie in 1920×1080.
    2.I separate fields (Upper) in “Interpret footage”.
    3.I make some graphic, color correct, move and scaled it, etc.
    4.I make a NTSC D1 composition
    5.I Drag the HD Comp into the SD Comp and fit it to Heigh.
    6.I render using Upper field first.
    As i mention before, the render should be Lower field first.
    So i wonder what would be the correct way to reverse it.
    Maybe if i take that render and move it one pixel up (or down) and then render it again ? (Without sepparating fields, and whithout choosing a field dominance in the render settings ?)
    Any help will be much appreciated
    Martin Fisher replied 16 years, 1 month ago 2 Members · 2 Replies
  • Michael Szalapski
    July 28, 2010 at 1:16 pm
    You’re downconverting HD to SD, so you’re going to be losing the HD fields in the loss of resolution anyway. I would say do what you did originally, except render out lower field first.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Martin Fisher
    July 28, 2010 at 3:59 pm
    ops ! the 720×480 was a mistake… im using 720×486.
    same thing with the export thing. i dont think i ever used the export function.
    sorry about those.
    and thank you both for the help !
    m.
