Activity Forums Adobe After Effects Expressions Reversing After Effects Expression Value
  • Reversing After Effects Expression Value
    Posted by Scott Horsfall on April 22, 2008 at 10:52 pm
    Quick question here, I’m a little new at After Effects, but here goes.
    I’ve got two wings that are set up and rotated opposite values. I want to rotate both wings at the same time to opposite values. If that makes sense. Think of a bird flying and both wings moving at the same time.
    I set up a null object and rotated it the way I wanted the left wing to rotate/move. I’ve also got the left wing working using the expression thisComp.layer(“Rotation”).transform.rotation . I want the same rotation values to be applied to the right wing, except the opposite/inverse values so that it moves at same time and same way as the left wing.
    Any ideas?
    Nathaniel Logan replied 6 years ago 3 Members · 3 Replies
  • Darby Edelen
    April 22, 2008 at 11:52 pm
    Try:
    -thisComp.layer("Rotation").transform.rotation;
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
  • Scott Horsfall
    April 23, 2008 at 4:33 pm
  • Nathaniel Logan
    August 26, 2020 at 10:39 am
