  • Posted by Göran Thorén on November 20, 2008 at 9:01 am
    probalbly a silly question but I can´t figure it out.
    How do I reverse the cale property in an expression?
    This is what I have:
    comp(“00148P.mov ansikte”).layer(“00148P.mov”).transform.scale
    Now I need that expreesion to do the reversed thing. Does anyone know?
    Thank´s!
    Göran Thorén replied 17 years, 9 months ago 3 Members · 6 Replies
  • Filip Vandueren
    November 20, 2008 at 11:29 am
    s=comp("00148P.mov ansikte").layer("00148P.mov").transform.scale;
    [10000/s[0],10000/s[1]];
    // or
    [10000/s[0],10000/s[1],10000/s[2]];
    Hi Goran,
    if by reverse you mean 50% -> 200%
    try this expression (for 2D)
    for 3D use the lqst line
  • Göran Thorén
    November 20, 2008 at 11:39 am
    Thank´s a million Filip! It worked like a charm!
  • Filip Vandueren
    November 20, 2008 at 1:13 pm
    of course, watch out for scale [0,0,0] you will get divide by zero errors
  • Göran Thorén
    November 20, 2008 at 2:32 pm
    Ok, will do.
    Could you explain what the expreesion does exactly?
  • Darby Edelen
    November 21, 2008 at 5:44 pm
    10000 is 100 squared.
    You’re dividing 100 squared by whatever your scale happens to be. So at 100% scale your result will be 100%:
    100 * 100 / 100 = 100
    This can also be written as:
    100 * (100 / scale)
    As you decrease the scale value below 100 the second term (100 / scale) will increase in value. At 50% scale the second term will evaluate to 2 which results in 100 * 2 or 200%:
    100 * (100 / 50) = 100 * 2 = 200%
    Does that help at all?
    Darby Edelen
  • Göran Thorén
    November 22, 2008 at 8:52 am
    Thank´s Darby!
    I´m really poor when it comes to math unfortunately, I´m more of a visual person. But it was well explained so I think I get the essense of it. 🙂
    I could never figure things like that out myself. I wish I could though. Thank god for guys like you!
    Göran
