Reverse Telecine Question
I just got footage that was shot 35mm, transferred to 1080p 23.98 HDCAM and then downconverted to DVCAM so I can do the offline edit. We plan to send it out to another facility to do the online back to HDCAM 1080p 23.98. I’ve digitized the footage 29.97 and will reverse telecine it to 23.98 in Cinema Tools.
Now my question is, when I do the settings of reverse telecine, do I need to pay special attention to the field order and getting that right on? There are no indications of which frame is the ‘A’ frame, so I can’t easily set that. Can I just simply reverse it to 23.98, without worrying about the other settings–Will that be a problem when it’s time to online?
Thanks for your suggestions.
Krisi
