reverse TC when A frame is on 1?
Got a load of dailies from argentina. A frame is on the 1’s. So batch reverse doesn’t work.
When I reverse telecine individual clips, cinema tools seems to be re-striping the timecode so that the 24fps A frame is on zero. So my burn-in code reads “01:00:00:01” but my timecode track is “01:00:00:00”
I understand there’s a variance because of the 30->24 translation. But shouldn’t there be a frame where both 30fps burn-in code and 24fps timecode track match perfectly? Normally if the A frames were on 0, then your codes would always match on the zero’s.
I’m only concerned because this is a project that will be finished in HD and I want my EDL’s to be spot on for the finishing house. And I’m a little rusty on my 3:2 theory.
THANKS!!!!!!
Glad to be back on the Cow
aaron
