Activity Forums Adobe InDesign Reverse table of contents
  • Reverse table of contents
    Posted by Elior Nadler on September 3, 2020 at 11:48 am
    helo,
    do some know if its posible to make a reverse table of contents, im working on book with tow sides, on one side it works perfect but on the other one i need the table of contents to stars from the end…..i hope i explain it ok.
    many thanks
    Kalleheikki Kannisto replied 5 years, 11 months ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    September 8, 2020 at 2:57 pm
    If the text is normal Western direction with one rotated 180 degrees and starting from end of the other, you’re better off making two separate books the normal way and combining at PDF stage for printing. If it is actually written backwards like Japanese or Hebrew, there are (or at least used to be) special versions of InDesign to handle such languages. ME for Middle Eastern, for instance.
