Activity Forums Adobe After Effects Reverse Path with Bezier Handles
  • Reverse Path with Bezier Handles
    Posted by Wouter Dijkstra on June 1, 2019 at 4:19 pm
    Hi Guys,
    Is there a way to reverse a path that uses “BEZIER HANDLES”.
    I made a nice curve between two keyframes and now want to put the 3rd that should give the same motion back to the first position with the same curve. Just pasting keyframe#1 doesn’t do the trick. Time Reversing keyframes neither. The only thing that I’m aware of that would work is the: LoopOut(pingpong) expression. But that would mean the whole layer will start looping and other later adjustments will not work.
    I don’t want to do it manually ???? I’m looking for a CLEAN look.
    Kalleheikki Kannisto replied 7 years, 3 months ago 3 Members · 6 Replies
  • Kalleheikki Kannisto
    June 2, 2019 at 7:38 am
    Time reversing keyframes should work. Did you copy both keyframes before time reversing them?
    Senior Graphic Designer
  • Wouter Dijkstra
    June 2, 2019 at 7:53 am
    Hi Kalleheikki!
    I tried both ways. I think when I would use 4 keyframes and 1 frame hold it would work like you described. The way I want it is with 3 keyframes only. Like in the screenshot, but I always get a sort of “circle” it never goes back the way it came.
    Am I doing it the wrong way?
  • Wouter Dijkstra
    June 2, 2019 at 7:56 am
    this setup (with a “hold”) works. But I don’t want 1 frame hold.
  • Tomas Bumbulevičius
    June 4, 2019 at 9:21 am
    Wouter, looking at first example with 3 keyframes – I wonder – that circular path happens to appear when you paste value of the first keyframe, aka, by trying to reset motion into its original state?
    Find out more:
    After Effects Tutorials: motion design, expressions, scripting.
    Boxer – Dynamic Text Boxes Template with a Live Preview
  • Wouter Dijkstra
    June 4, 2019 at 1:48 pm
    Exactly. So once I put the first keyframe again, the movement becomes (sort of) circular. Adding 4 keyframes (last two “Time Reverse”) makes it happen, but it gives one frame hold. I don’t want a hold 😉
    June 4, 2019 at 2:32 pm
    You might be better off editing the motion path in the graph editor to be symmetric. You may need to separate dimensions as well.
