Activity Forums Adobe After Effects Reverse Path / Mask Direction
  • Reverse Path / Mask Direction
    Posted by Mecha on June 5, 2005 at 11:14 am
    Hey All,
    How do you reverse the direction of a path in a mask? I need to animate some letters appearing using mask shapes (imported form AI CS2) and 3D Stroke.
    I know about “set First Vertex” but that screws up the path shape and doesnt actually reverse the 3D Stroke effect, it just starts it from a different place but still animating in the same direction!
    Any ideas?
    thanks in advance,
    mecha
    Ermal Koci replied 3 years, 11 months ago 5 Members · 4 Replies
  • Steve Roberts
    June 5, 2005 at 12:48 pm
    You don’t change the mask direction, you animate the start and end parameters of the stroke differently: start with both parameters at 100, then animate the start parameter down to 0.
    Unless I missed the question … 🙂
    Steve
  • Nick Haffie-emslie
    December 19, 2007 at 12:10 am
    I’m curious about this too actually. Your solution is fine for stroke but what about copying Mask data and pasting it into the Position of another layer (so the layer follows the path)? You could precomp and time-reverse but this seems sloppy…
  • Andrew Jehan
    March 18, 2022 at 3:41 am
    This script does it. Note, the path cannot have any keyframes and you have to select the shape as opposed to the path itself before clicking reverse (or it won’t work).
    https://aescripts.com/first-vertex-toolkit/
  • Ermal Koci
    October 1, 2022 at 12:52 pm
    Right click on the mask>Close mask>set first vertex>right click on part of the mask between two vertices you want to remove>uncheck Close mask.
    This should reverse mask direction. Unfortunately if you have animated it, you should do this for all the keys.
