Activity Forums Adobe After Effects Reverse linear wipe expression
  • Reverse linear wipe expression
    Posted by Rory Flynn on May 17, 2017 at 9:59 pm
    I am trying to drive a linear wipe transition with the y rotation on another layer. So I have linked them using the pick whip. This works however it animates from 0-100%. I need it to animate from 100-0%. Is there something I can put in the expression to reverse it?
    Rory Flynn replied 9 years, 3 months ago 2 Members · 2 Replies
  • Walter Soyka
    May 18, 2017 at 3:22 am
    linear(x, 0, 100, 100, 0);
    Replace x with your pick-whipped property.
    In English, this code says, “as x goes from 0 to 100, return a range from 100 to 0.”
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Rory Flynn
    May 18, 2017 at 10:10 am
    That’s perfect. Thanks Walter.
