Activity Forums Adobe After Effects Expressions reverse layer order in whole project
  • reverse layer order in whole project
    Posted by Lars Pedersen on December 13, 2013 at 4:08 pm
    hi!
    Is there a way to script an script that can reverse layer order in all selected comp’s?? Found a script that does it on aescripts.com but that requires to select the layers and press a button and i have 60+ comps that needs it fixed.
    Thanks.
    James Retling replied 11 years, 12 months ago 3 Members · 3 Replies
  • Dan Ebberts
    December 13, 2013 at 6:20 pm
    Something like this should work:
    var myItems = app.project.selection;
    var myComp;
    for (var i = 0; i < myItems.length; i++){ if (myItems[i] instanceof CompItem){ myComp = myItems[i]; for (var j = myComp.numLayers -1 ; j > 0; j--){
    myComp.layer(j).locked = false;
    myComp.layer(j).moveToEnd();
    Dan
  • Lars Pedersen
    December 13, 2013 at 6:52 pm
    thanks Dan 🙂 You’re a legend and just save my day. I gave you a small tip in the tip jar @https://www.motionscript.com
  • James Retling
    September 24, 2014 at 9:21 pm
    Found this on another creative cow answer.
    Click the layer you want to be the first layer, shift click the layer you want to be the last layer, then cut (ctrl/cmd+x) and paste (ctrl/cmd+v). Voila!
