Activity Forums Adobe After Effects Expressions reverse expression?
  • reverse expression?
    Posted by Phil on March 16, 2006 at 11:21 pm
    setup:
    2 layers.
    problem:
    i would like to link one layers position to the other, but make in an inverse relationship so that when i move the first layer up, the second layer moves down, etc.
    i know how to pick whip, but its the actual written expression i’m looking for. thanks soooooom muches.
    Mahmoud Abd elatti replied 11 years ago 4 Members · 5 Replies
  • Andrew Kramer
    March 16, 2006 at 11:47 pm
    thisComp.layer(“LayerName”).transform.position*(-1)
    basically use the pick whip but multiply it by negative 1.
    then add or subract a number to get the correct offset relative to your layer.
    thisComp.layer(“LayerName”).transform.position*(-1)+720
    This way isn’t perfect because it depends where your layers start you could also add nulls to offset layer by parenting them.
    Andrew
    I’m sure there is a better way but…
  • Ryan Hill
    March 17, 2006 at 7:08 pm
    I think you might add the anchor points of the two layers, instead of just an arbitrary 720.
  • Phil
    March 17, 2006 at 8:25 pm
    thanks guys, i will give it a go 🙂
  • Phil
    March 17, 2006 at 9:22 pm
    i just need the ‘Y’ position to move opposite of it…the x & z should stay the same……
    thanks!
  • Mahmoud Abd elatti
    August 27, 2015 at 12:13 pm
    How could i reverse position of a layer connected to null in a certain point in x or y
