Activity Forums Apple Final Cut Pro Legacy Reverse Clip Problem (Speed Change)
  • Reverse Clip Problem (Speed Change)
    Posted by Robert Lawhead on April 20, 2005 at 5:07 am
    Several times I’ve needed to reverse the direction of a clip … I highlight it, go to Speed Change and check ‘Reverse’ (with no speed change … I’ve tried frame blending both on and off). It looks great in my viewer and canvas on the computer monitor, but the NTSC monitor looks AWFUL …. very jerky and unsteady. Totally unuseable. My monitor is from the output (S-Video) of an AJA IO. Am I missing something like a setting? …. or could the AJA be having difficulty in doing the math? Thanks in advance for any suggestions!!
    Martin B. wehding replied 21 years, 5 months ago 6 Members · 5 Replies
  • Thaxter Clavemarlton
    April 20, 2005 at 10:18 am
    Did you RENDER the reverse clip, then view it externally?
  • John Grilli
    April 20, 2005 at 3:07 pm
    Try reversing the fields. That should fix the problem.
  • Graeme Nattress
    April 20, 2005 at 3:24 pm
    Use my free G reverse plugn – http://www.nattress.com
    Graeme
    http://www.nattress.com – Film Effects for FCP
  • Blub06
    April 20, 2005 at 6:30 pm
    You said you selected it, the clip, did you do this from the time line, was the clip on the time line when you selected it?
    If so, don
  • Martin B. wehding
    April 21, 2005 at 6:50 pm
    Yes, use Graemes reverse filter. FCPs own reverse is horrible. It’s like you described it, very jerky, because of the reversed fields.
    I always use Graemes.
    BTW. his Film Effects filters is highly recomended.
    Regards
    MartinW
    Martin Wehding, Editor.
    Fabelfilm.
    Final Cut Pro 4.1
    G5 Dual 2GHz, 1Gb ram
    500Gb LaCie Big, FW800
    2x320Gb LaCie Big, FW800
    23″ Cinema display
    BM DeckLink Extreme
