Activity Forums Apple Motion Reverse behavior in 3D
  • Reverse behavior in 3D
    Posted by Naor Yuval on April 3, 2012 at 1:19 pm
    I have a logo made out of many shapes that I wish to fly on a path as a swarm, followed by the camera and have the pieces move into place at the end of the clip.
    I have started from the assembled logo, added random motion and a motion path. however, to reverse it all I need to create a duplicate layer, add a reverse behavior and have the camera follow it.
    The problem is that creating a duplicate layer makes a 2D layer of the motion and flattens the Z axis.
    The other option I see is to keyframe the entire animation however the logo has MANY shapes and that would take forever.
    can anyone advise of a better way?
    Naor Yuval replied 14 years, 5 months ago 2 Members · 2 Replies
  • Mark Spencer
    April 3, 2012 at 2:44 pm
    You can try cloning the full animation (put it all in a group and clone the group) and then retiming the clone to reverse it – however, with a 3D animation, sometimes the clone won’t look correct due to flattening. Your other option is to export the full animation as rendered movie, bring it back in, and reverse it.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Naor Yuval
    April 5, 2012 at 12:27 pm
    Thanks Mark.
    Reverse does not work with a group only a clone-layer which flattens the 3D into 2D.
    I ended up exporting to clip and reversing in FCP.
    I still find it annoying that motion has no solution for this common workflow issue
    naor
