Activity Forums Apple Motion reverse an object
  • reverse an object
    Posted by Max Frank on June 7, 2007 at 11:10 am
    I created a rectangle object in Motion 2, and keyframed a special
    path from left to right.
    Now I want to have a duplicate of that rectangle to move in the exact
    opposite direction at the exact speed.
    Is there a way to reverse an object/path in Motion 2?
    Thanks in advance,
    Wayne
    Max Frank replied 18 years, 11 months ago 2 Members · 2 Replies
  • Doyle Rockwell
    June 7, 2007 at 2:56 pm
    You sure can, through the cunning use of the diabolically-named Reverse behavior 😉
    Motion has a special class of behaviors called parameter behaviors. Instead of being applied to the whole object, they are applied to a specific parameter. For example, you might apply Randomize to an object’s Opacity to make it flicker.
    In your case, just apply a Reverse behavior to the Position parameter of your animated object. Right-click on the “Position” parameter label in the Inspector and pick Reverse from the menu.
  • Max Frank
    June 7, 2007 at 9:16 pm
    Specialcase,
    Thanks so much — that’s why you get paid the big bucks 😉
    All the best,
    Wayne
