Activity Forums Adobe After Effects Expressions Reverse a expression
  • Reverse a expression
    Posted by Gijs Ten den on January 11, 2017 at 10:03 am
    Hello,
    Quick question, I am trying to reverse a expression in After Effects but after searching for like an hour I still don’t have anny clue.
    The expresion that I am trying to reverse is: ” thisComp.layer(“Joep”).content(“Trim Paths 1”).end “.
    The expression links to a trimpath of a round shape layer, and i am trying to link it to a radial whipe effect but I need to reverse the value.
    Because the trimp path goes from 0 to 100 and the radial whipe from 100 to 0.
    Help is welcome ????
    thisComp.layer("Joep").content("Trim Paths 1").end
    Gijs Ten den replied 9 years, 8 months ago 2 Members · 2 Replies
  • James Ronan
    January 11, 2017 at 1:03 pm
    There is probably a better way but I’d do it like this:
    x = thisComp.layer("Joep").content("Trim Paths 1").end;
    linear(x,100,0,100,0);
  • Gijs Ten den
    January 11, 2017 at 1:10 pm
    Better way or not it works????
    Thank you for your help!
