Activity Forums Adobe Illustrator Revealing Layer Effects
  • Revealing Layer Effects
    Posted by Dane Cannon on November 9, 2010 at 6:27 pm
    Hey All
    I’ve got experience with AE and PS, and somehow I’ve found myself stumbling through the AI world. This is a noob question, but I’ve applied the roughen edges effect to several text layers. I now want to copy that effect to a shape. How do you display the effects? I’m assuming it exists somewhere (and is probably still editable), I just can’t seem to find it!
    Dane
    Dane Cannon replied 15 years, 9 months ago 2 Members · 3 Replies
  • Les Nemeth
    November 9, 2010 at 6:44 pm
    1. Expand your layers palette.
    2. After the objects’ name, on the right, you will see little circles. The object(s) that have effects applied will have a filled, greyish circle, the ones don’t have effect will have a circle.
    3. Hold down Alt, click on the filled circle (which represent the effect(s) applied to the object) and drag it over to the object you want to have the same effect.
  • Les Nemeth
    November 9, 2010 at 6:45 pm
    And by the way, the effects are displayed in the appearance palette.
  • Dane Cannon
    November 9, 2010 at 6:53 pm
    Boo yah. THANKS a ton.
