Activity Forums Adobe After Effects Expressions Reveal Text using ease(), inPoint, outPoint
  • Reveal Text using ease(), inPoint, outPoint
    Posted by Jake Nelson-dooley on October 19, 2018 at 1:46 pm
    Hi expression folks,
    I’m trying to create a preset that reveals and hides lines of text – trying to approximate the manual masking effect, or “shape reveal” text effect you see frequently.
    Using a combination of Fast Box Blur, Curves, and CCcomposite (creates a box to use as an alpha), plus two different Transform effects (moving the text in and out of the alpha box) I was able to get a single text layer that reveals and hides itself based on the In and Out points… However, when saved as a preset and applied in a new Comp, it does not work anymore.
    I must’ve made a mistake. If anyone can help me spot it, I’d really appreciate it!
    p.s. if there’s an existing preset for this, that’s good too ☺
    //##########First Transform Effect#################
    //need the height of the text layer
    var x = sourceRectAtTime();
    //adding a few extra points padding
    x_distance = x.height+3
    //set duration equal to slider
    durationIn = effect("durationIn")("Slider");
    durationOut = effect("durationOut")("Slider");
    if(time<(inPoint+outPoint)/2)
    //using easeOut with duration to slide the layer up
    easeOut(time,inPoint,inPoint+durationIn,[this.position[0],this.position[1]-x_distance],[this.position[0],this.position[1]]);
    else
    easeIn(time, outPoint-durationOut, outPoint, [this.position[0],this.position[1]],[this.position[0],this.position[1]+x_distance]);
    //##########Second Transform Effect#################
    easeOut(time,inPoint,inPoint+durationIn,[this.position[0],this.position[1]+x_distance],[this.position[0],this.position[1]]);
    else
    easeIn(time, outPoint-durationOut, outPoint, [this.position[0],this.position[1]],[this.position[0],this.position[1]-x_distance]);
    Jake Nelson-dooley replied 7 years, 10 months ago 2 Members · 2 Replies
  • Filip Vandueren
    October 20, 2018 at 10:45 pm
    If I understand your desired effect correctly (a simple Wipe down ?)
    I would do it with two linear Wipes like this:
    Wipe In efect: Wipe Angle = 0°, expression for Transition Completeness:
    sr = thisLayer.sourceRectAtTime();
    // get all cornerPoints, the layer could be rotated, so we need to check every corner for top/btoom status
    TL=toComp([sr.left, sr.top]);
    TR=toComp([sr.left+sr.width, sr.top]);
    BL=toComp([sr.left, sr.top+sr.height]);
    BR=toComp([sr.left+sr.width, sr.top+sr.height]);
    textTop = Math.min(TL[1],TR[1],BL[1],BR[1]);
    textBottom = Math.max(TL[1],TR[1],BL[1],BR[1]);
    min= 100*textTop/thisComp.height;
    max=100*textBottom/thisComp.height;
    t1=inPoint;
    t2=inPoint+effect("durationIN")("Slider").value;
    100 - ease(time,t1,t2,min,max); // the WipeIn angle is 0° and works kinda backwards
    WipeOut: Wipe Angle = 180° and expression for Transition completeness=
    t1=outPoint - effect("durationOUT")("Slider").value;
    t2=outPoint;
    I used ease(), but you can use linear, easeIn() etc.
  • Jake Nelson-dooley
    October 22, 2018 at 12:25 pm
    Thanks Filip, your code helped me get this working!\
    If anyone wants to know, the mistake I made originally was to use this.position inside of the transform effect:
    I realize now the transform effect position values are constant at [960,540] for a 1080p composition.
    Besides that, Filip’s linear wipe approach is better than the “alpha box” I had before. I just added a transform effect to his code so the text slides up and down while it’s being revealed.
    Cheers!
