Activity › Forums › Adobe Encore DVD › Return to main menu
  • Return to main menu
    Posted by Hector Melendez on December 5, 2005 at 2:42 pm
    I have been working sucessfully with Encore. Now, my main difficulty is that
    after playing back till the end of the DVD the screen remain black instead of returning to main menu. Couldn’t find a way how to set this correctly.
    please help. Thanks in advance
    Hector Melendez replied 20 years, 9 months ago 2 Members · 4 Replies
  • David Garrett
    December 5, 2005 at 3:10 pm
    if you only have one timeline then set it’s “end action” to return back to the main menu, or if you have multiple timelines then set the last timeline’s “end action” to return back to menu after playing
  • Hector Melendez
    December 9, 2005 at 6:40 am
    Couldn’t find how to set this after several hrs of try-out. Could you explain the steps?
  • David Garrett
    December 9, 2005 at 6:51 am
    click on the timeline to select it, now look over to it’s properties and you will see “end action” and “override”, make sure the “end action” for this timeline is set to return back to the menu. just click on the pickwhip and drag it out and drop it onto the main menu within the project window and then release the pickwhip
  • Hector Melendez
    December 9, 2005 at 7:17 pm
    Thanks… Finished this project… will try next. Don’t know why the final disc when finished repeated the last chapter and then returned to main menu.
    Could be I did something after so many tries.
