Activity Forums Adobe Encore DVD Return to loop ponit at Encore CS5
  • Return to loop ponit at Encore CS5
    Posted by Carlos Rocha on July 29, 2011 at 12:41 pm
    Hi Everybody!
    I have a Video to the Menu with 38 seconds. I have done a loop point at 23:27 seconds and would like the movie of timeline, at run all, return to Menu but to the loop point and no to begining of Menu.
    How i do it?
    Thanks.
    Carlos Rocha replied 15 years, 1 month ago 2 Members · 5 Replies
  • Jon Geddes
    July 29, 2011 at 5:03 pm
    Set the End Action of the movie timeline to return to the loop point of the Main Menu.
    Click the drop-down arrow in the field for the timeline’s end action, then go down and select ‘Specify Link’. In the window that pops up, select the main menu (and a particular button if you want), then at the bottom of the window, make sure “Set to Loop Point” is checked, then click OK.
    Jon Geddes
    http://www.precomposed.com
  • Carlos Rocha
    July 29, 2011 at 9:08 pm
    This form?
    http://www.carcleo.com/img.png
    Not work.
    Sorry.
    I am a brasiliam.
    Please, not see to my “English”. Ok?
    Thank you
  • Jon Geddes
    July 29, 2011 at 9:59 pm
    Have you tried building your disc?
    The Encore preview is not an accurate representation of how the final disc will function.
    Jon Geddes
  • Carlos Rocha
    July 29, 2011 at 10:21 pm
    Ok.
    I yet not tried.
    I will try and later put here the result.
  • Carlos Rocha
    July 29, 2011 at 10:37 pm
    Yes.
    It is.
    Thank you for all.
    So work.
    At prewier of Encore not work. But, buildind, yes. Work.
    Thank you again.
