Activity Forums Adobe After Effects Expressions Return positive values only
  • Return positive values only
    Posted by Alejandro Benavente on September 9, 2009 at 11:28 am
    Hi there.
    I have an expression-driven scale property for a layer. Now, my expression returns positive and negative values; I’d like to discard the lattest, so that positive values are used, yet negative ones are discarded as 0.
    I’ve found a lot of answers that use the Math.abs expression, yet this wouldn’t work for me, as negatives would turn positive with the same absolute, not 0, which is what I need.
    I think the solution must be really simple; sorry if this has been answered before, I’ve done some search without success.
    Thanks a lot.
    A.
    Alejandro Benavente replied 17 years ago 2 Members · 2 Replies
  • Dan Ebberts
    September 9, 2009 at 12:44 pm
    Separate your scale vaule into x and y components and then use something like this:
    [Math.max(x,0), Math.max(y,0)]
    Dan
  • Alejandro Benavente
    September 14, 2009 at 9:20 am
    Hi, Dan.
    I succedeed with a different approach before reading your hint.
    I’ll give it a try, though, to check if it works.
    A.
