Activity Forums Adobe After Effects Retrieving frame from video stream — error 53::54
  • Retrieving frame from video stream — error 53::54
    Posted by Timo_hh on August 15, 2005 at 7:50 am
    Hi everybody,
    the issue is often discussed on the board in the past, but it seems to me, that there is no definite solution. To me, it happened as well with After Effects 6.5 Pro. I upgraded my Workstation from 1 to 2 GB Ram (ECC) and became those error messages shown above while redering big projects. The message came with different codecs, but mostly from the built in Matrox DV from the RTX 100. Capturing and cutting in Premiere 1.5 than importing into AE.
    I already trashed the prefs. But it did not help.
    Please, if anyone out there has got the same problem fixed, please reply to this message. I am losing day after day…
    Thx a lot
    Ebarfield replied 21 years ago 2 Members · 1 Reply
  • Ebarfield
    August 15, 2005 at 7:55 pm
    I had similar problem recently, but don’t think it was the same. I will tell you how I solved mine, and you can see. I had a complex project, with 4 comps. I was trying to render in DV/AVI, which requires 720X480, I believe (or is it 486?). anyway, my “feeder” comps, and my main comp, were set as 640X480 comps. When I changed all comps to a true DV setting, then rendered as DV AVI, the error went away.
    egb
