Activity Forums Adobe After Effects Expressions Retrieve source text value to be used as color hex value
  • Retrieve source text value to be used as color hex value
    Posted by Christian Simpson on April 5, 2023 at 7:41 pm
    I am setting up mogrt templates using spreadsheet data. My goal is for a user to enter 6 digit hex value in the spreadsheet and for that value to be picked up in my mogrt. The only way I can think to do this is is to have some hidden text that receives the hex value from the spreadsheet that gets passed onto the color property. Maybe there is a better way?
    Brie Clayton replied 3 years, 5 months ago 4 Members · 4 Replies
  • Yoan Boisjoli
    April 5, 2023 at 8:11 pm
    Hi Christian! I think you can add this expression to you color property and it should do the trick:
    hexColorSource = thisComp.layer("Hidden text").text.sourceText;
    hexColor = hexColorSource.value.toString();
    r = parseInt(hexColor.substring(0, 2), 16) / 255;
    g = parseInt(hexColor.substring(2, 4), 16) / 255;
    b = parseInt(hexColor.substring(4, 6), 16) / 255;
    [r, g, b, 1]
  • Dan Ebberts
    April 5, 2023 at 8:19 pm
    If your spreadsheet is a .csv file, I think you can go right to your hex data with a color expression like this:
    c = footage("hex color test.csv").dataValue([0,0]);
    hexToRgb(c)
  • Christian Simpson
    April 6, 2023 at 5:08 pm
    Thank you very much gentlemen, worked like a charm. Very much appreciated.
  • Brie Clayton
    April 7, 2023 at 1:30 am
    Thank you Dan and Yoan!
