Activity › Forums › Adobe After Effects › Retrieve aeProjectLink from XMP data with Extendscript
  • Retrieve aeProjectLink from XMP data with Extendscript
    Posted by Dan Racusin on December 4, 2019 at 11:11 pm
    Please help! I am trying to get this path stored as a string /Users/dracusin/Desktop/CollectorTestProject.aep
    This is from the files XMP. I can see the line in bridge(vie FileInfo) but not in the AE metadata panel.
    Here is my current function:
    function GetMetaData(){
    var item = app.project.activeItem;
    var selectedFile = new File($.fileName);
    var itemPath = selectedFile.parent.fsName;
    var filePath = itemPath + "/" + item.name;
    var fileRef = new File(filePath);
    if (fileRef instanceof File) {
    if (ExternalObject.AdobeXMPScript == undefined) {
    ExternalObject.AdobeXMPScript = new ExternalObject('lib:AdobeXMPScript');
    var xmpFile = new XMPFile(filePath, XMPConst.FILE_UNKNOWN, XMPConst.OPEN_FOR_READ);
    var xmp = xmpFile.getXMP();
    var newXML = xmp.getProperty(XMPConst.NS_CREATOR_ATOM, 'fullPath');
    alert("Error: " + newXML);
    xmpFile.closeFile();
    This line returns the correct data for some reason:
    var newXML = xmp.getProperty(XMPConst.NS_XMP, ‘CreateDate’).toString();
    2019-11-27T19:49:44Z
    This line does not:
    var newXML = xmp.getProperty(XMPConst.NS_CREATOR_ATOM, ‘fullPath’);
    /Users/dracusin/Desktop/TestProject.aep
    Any ideas?
    Dan Racusin replied 6 years, 9 months ago 2 Members · 2 Replies
  • Walter Soyka
    December 5, 2019 at 2:53 pm
    I couldn’t figure out the clean way to do this — NS_CREATOR_ATOM doesn’t seem to be a registered namespace — so here’s a hacky code fragment to do it instead:
    // take the whole XMP object and make it into a string so we can parse it manually
    var xmpString = xmp.dumpObject().toString();
    // use a regular expression to find the fullPath item of the aeProjectLink struct of the creatorAtom
    var creatorFsName = xmpString.match(RegExp('(.*creatorAtom:fullPath = ")(.*)(")'))[2];
    alert(creatorFsName);
    You should add some error checking to this, because as written, it will fail hard if there’s no project link data.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Dan Racusin
    December 6, 2019 at 6:22 am
    Thank you Walter! This works perfect for what I need. I was so excited when this worked I jumped out of my seat.
