Activity Forums Adobe Premiere Pro Retreiving sound track
  • Retreiving sound track
    Posted by Verdoni Philippe on February 17, 2006 at 4:45 pm
    It incidently happens that I loose the sound track associated with a video footage (i.e. the audio track on the timeline becomes blank in regard of the video). I had used a procedure enabling to retreive the lost sound track which I cannot remember. It was based on the use of the “T” shortcut after the CTE is placed at the beginning of the video clip and the relevant video track had been activated; but I am probably mising a step since the procedure does’nt work. Can someone be so kind as to refresh my aging memory. Thanks.
    Hector Melendez replied 20 years, 6 months ago 2 Members · 1 Reply
  • Hector Melendez
    February 17, 2006 at 10:01 pm
    Undo didn’t worked?
    If not you can down the clip again from the capture bin… maybe in another secuence; make the trim again if you did some and copy paste to your working Timeline… just an example of what I will do.
    Didn’t know other ways!
