Activity Forums Adobe After Effects Expressions Retreive data from button built with for loop
  • Retreive data from button built with for loop
    Posted by Hugo Cormier on December 6, 2020 at 3:33 pm
    Hello everyone,
    First of all, thank you to feed this forum, it is super usefull !
    I am trying to build an interface whith a script, wich displays all the aep projects in a folder, and allows to open the one you selected (kind of a browser for templates).
    For now, I am able to choose a folder, scan it and get all the after effects projects in there.
    But when building the UI, I use a for loop to create iconbuttons on the fly, based on the number of projects to display.
    It works, but when the ui is built with all my iconbutton, I have no clue how to retreive data from the button clicked (I usally have a variable by button but can’t do that with a loop).
    There is the code :
    //Define different paths
    var rootFolder = "D:/_WIP/2020_10_TF/dev/BROWSER/SAMPLE_FOLDER";
    var emission = "ACDC"
    var projectFolder = rootFolder + "/" + emission + "/Projects";
    var thumbnailFolder = rootFolder + "/" + emission + "/Thumbnails";
    var templateList = [];
    loadTemplates(projectFolder);
    //Scan folder with templates and stores their name in an array
    function loadTemplates(folderPath) {
    templateList = [];
    var files = Folder(folderPath).getFiles("*.aep", "*.aet");
    for (i = 0; i < files.length; i++) {
    var file = files[i];
    templateList.push(file.name.slice(0, -4));
    //Build UI
    var w = new Window("palette", "Templates");
    var thumbnailPanel = w.add("panel {orientation: 'column'}");
    w.show();
    //Adding Thumbnails
    for (i = 0; i < templateList.length; i++) {
    currentThumbnail = File(thumbnailFolder + "/" + templateList[i] + ".jpg");
    //Check if a thumbnail exists for the specified template
    if (currentThumbnail.exists == false) {
    currentThumbnail = File("D:/_WIP/2020_10_TF/dev/BROWSER/SAMPLE_FOLDER/Missing_Thumb.png");
    var button = thumbnailPanel.add("iconbutton", undefined, currentThumbnail, {
    style: "toolbutton"
    button.name = templateList[i];
    thumbnailPanel.add("statictext", undefined, templateList[i]);
    w.layout.layout(true);
    //---> looking for a function to get the proper value based on wich button i clicked
    button.onclick = opentemplate(button.name);
    function opentemplate(name) {
    alert(name);
    The idea would be that the button returns a string (name of the file), then I can use it to access the .aep
    Maybe I should build the ui otherwise than a foor loop ?
    I hope this is clear,
    Best regards
    Hugo
    Matt Volp replied 5 years, 8 months ago 2 Members · 1 Reply
  • Matt Volp
    December 8, 2020 at 12:41 am
    If you’re after the button to return the button’s name, try this:
    button.onClick = function() {
    alert(this.name);
