Activity Forums Adobe Premiere Pro Retina display and CS6 compatible?
  • Retina display and CS6 compatible?
    Posted by Andrew on June 18, 2014 at 12:30 am
    Hi guys,
    I’m aware there’s no work around for the pixalation/magnification issues caused by Apple’s High res retina display when using CS5. With the exeception of Photoshop and Illustrator.
    I use Premiere Pro and AE a lot and was wondering if I upgraded to CS6, is the issue rectified? I read that the update 6.0.2 fixes all pixalation issues no matter what program you use in CS6. Is that the case?
    If this is true, where can I buy a legit copy of CS6 these days? CC is just to expensive for me and reading the forums, sounds like a nightmare!
    Thanks in advance
    Andrew replied 12 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
