Activity › Forums › Adobe After Effects › Retangular Shatter Effect in AE
  • Retangular Shatter Effect in AE
    Posted by Chris Comley on November 13, 2012 at 10:11 pm
    Hello everyone.
    I’m creating an animation where text zooms in from behind the camera and slams into basketball court. I would like the court to break and crack behind where the text lands.
    I’ve been able to achieve basically what I want using the shatter effect. BUT… I’ve only been able to use the shatter effect with the force shape being round.
    Naturally a round hole in a floor doesn’t look like it came from a long rectangular piece of text slamming into it.
    So my question, is there any way to change the shape of the force within the After Effects Shatter effect?
    Or does anyone know of any other shatter plugins that I could use to get this?
    Walter Soyka replied 13 years, 10 months ago 3 Members · 6 Replies
  • Mathew Fuller
    November 13, 2012 at 10:42 pm
  • Mathew Fuller
    November 13, 2012 at 10:43 pm
    ^^^^ I think the procedural crumble tutorial is what you are looking for.
    My Work:
    https://www.morecompletefx.com
  • Chris Comley
    November 14, 2012 at 4:57 am
    I appreciate the response and pointing me to those videos. They will help me make what I want look more realistic, but they’re not what I’m really looking for.
    I’m not currently at work, so I can’t show you an exact screenshot, but I quickly made this at home.
    Pretend that’s a basketball court. I want the text to fly down and hit the basketball court (which is the easy part) and then I want to be able to shatter the court just like above, but more realistic. As you can see, it looks more like the “POW” box from a comic book or something.
    I watched the Procedural Crumble tutorial, but all that’s gonna show me is how to crumble out the text. I technically need to “crumble” out a portion of the background and have it look real instead of comic-book-ish.
    Any ideas?
  • Walter Soyka
    November 14, 2012 at 6:46 am
    [Chris Comley] “I watched the Procedural Crumble tutorial, but all that’s gonna show me is how to crumble out the text. I technically need to “crumble” out a portion of the background and have it look real instead of comic-book-ish.”
    You can’t follow the tutorial precisely step-by-step if you want a slightly different result than the demo video — you need to customize it to your specific needs. In this case, you’ll need to create the shape you want crumbled out and use that as a source in the procedural crumble instead of the text layer.
    Walter Soyka
  • Chris Comley
    November 14, 2012 at 6:52 am
    I kind of have it set up like that already, just in a different way. But in the end, it’s the same effect.
    The problem is, I can’t create the cut out shape, I need After Effects to create it.
    Sadly, I’m not that good with creating things manually so I’m not able to create a shape that looks natural. As you can see above, the best I can do is the “comic-bookish” look.
    The shatter effect with the shape set to glass is perfect. Just I need the force to be square and not circular.
  • Walter Soyka
    November 14, 2012 at 7:07 am
    [Chris Comley] “The problem is, I can’t create the cut out shape, I need After Effects to create it… The shatter effect with the shape set to glass is perfect. Just I need the force to be square and not circular.”
    How about creating a solid or shape the size you need, then mucking it up with Roughen Edges [link]?
    Alternate suggestions: use only the first couple frames of Shatter to crack the floor instead of shattering it outright (or use Advanced Lightning to create cracks) in combination with some dust elements (either stock image or particle system) when the text lands on the floor.
    Walter Soyka
