Activity Forums Adobe After Effects Expressions retaining value
  • Posted by Mo on April 21, 2007 at 10:24 am
    i was wondering how to retain a certain value for use later.. for example, i have 2 layers and layer2’s position is simply following layer1’s position. layer1 is just steady moving from left to right. layer2’s opacity is keyframed to go from 100 down to 25. when it gets to 25, i want it to stop where it is, so basically at the position of layer1 at the time that layer2 reaches opacity of 25.
    so i guess something like this:
    if (thisLayer.opacity.valueAtTime(time) == 25){
    [myPos[0], myPos[1]]
    } else {
    myPos = thisComp.layer(“layer1”).transform.position
    position = myPos
    of course the issue is when opacity is 25, AE doesnt know what myPos is yet. can i declare it somewhere? it seems like the script is read and ran every frame, so putting something at the top is useless since it just gets cleared every frame…
    thanks.
    m
    Dan Ebberts
    replied 19 years, 5 months ago
    3 Members · 3 Replies
  • Filip Vandueren
    April 21, 2007 at 11:14 am
    The work around is to first ‘read’ all the values the opacity has had between 0 and ‘now’ using a for-loop an valueAtTime()
    like this:
    fd=thisComp.frameDuration/2;
    p=thisComp.layer("layer1").transform.position;
    for (t=0;t 25) {
    p=thisComp.layer("layer1").transform.position.valueAtTime(t); }
    p;
    If the opacity starts to raise again, the layer will jump to the new position.
  • Mo
    April 21, 2007 at 4:11 pm
    thanks! thats idea worked. i coded it in a slightly different way but that idea worked.. however, isn’t the need to do this a bit cumbersome? really no other way, huh?
    thanks again.
    m.
  • Dan Ebberts
    April 21, 2007 at 6:34 pm
    Assuming that 25% occurs at the last opacity keyframe, this should work:
    t = Math.min(transform.opacity.key(transform.opacity.numKeys).time,time);
    thisComp.layer(“layer1”).transform.position.valueAtTime(t)
    Dan
