Activity › Forums › Zaxwerks › Retaining original Illustrator file colors
  • Retaining original Illustrator file colors
    Posted by Van Grafton on March 27, 2013 at 4:25 pm
    I am brand new to Invigorator and struggling through the initial learning curve. I have imported a logo created in Illustrator and want to keep the original colors. I checked the “Retain Colors” checkbox during import, but I still lose the original file colors. No doubt this is simple user error/ignorance on my part. Any advice would be appreciated.
    Thanks in advance.
    van
    Edward Wu replied 13 years, 6 months ago 2 Members · 1 Reply
  • Edward Wu
    March 28, 2013 at 6:19 pm
    Hi Van,
    Be sure you are using RGB colors and are not using gradient colors. If you are using a gradient color, you will have to either apply the gradient color as a texture map, which means first saving the color as a jpeg image and importing the image into Invigorator, or creating the gradient color in Invigorator instead.
    Also, in Illustrator, be sure you are working with a fill color and remove the stroke. If you have a stroke on your object, this will cause the colors to not show up correctly.
    If you have any questions, please let me know.
    Best,
    Edward
