Retaining Compression and Edit Markers in Compressor
Hi there.
I have a long HD project to make into a DVD stream. I want to downsize it to SD in a quicktime movie before I create the stream, as that downsizing process takes a long time and I need to create multiple versions of the stream. Frame controls are on because without them I’m getting flickery artifacts around the edges, so the process is taking a long time.
My problem is that the compression and edit markers are not retained when I downsize from one QT to another. Is there a way to pass them through when I export a new QT in compressor? Here’s what I’ve done:
1. Saved a self-contained QT from FCP in original settings with DVDSPRO markers.
2. Took the exported HD QT into Compressor (markers are all there at this point), exported a QT that takes the file from 1080i to 480i. Note: In the Compressor QT settings Inspector, there is no option in the Encoder tab to keep metadata, as there is in the MPEG2 settings inspector.
3. When I open that SD QT in Compressor for the purpose of creating the MPG2 stream, all the editing and compression markers are gone (chapter markers remain). This seems like a “dealbreaker” to me, as the compression markers are there for the sake of the stream, not the QT.Is there any way to export and import just the markers? That step #2 was an overnight render and I’d rather not start it again, if there’s a way to import the markers. Should I not worry about this for some reason? Is my workflow all wrong? I really don’t want to do an 18 hour render job every time I want to make a stream with new settings. And yes, I have read the Ken Stone pages on compression and all the relevant apple manuals, before anyone asks.
Someone also posted in a thread that they had good luck downsizing in After Effects, which I would consider doing if I could bring in the compression markers. I assume that AE doesn’t retain them either?
Melissa
