Activity Forums Adobe After Effects Retaining a layers 3d positioning when nested in another composition
  • Retaining a layers 3d positioning when nested in another composition
    Posted by Joey Campbell on August 28, 2013 at 9:45 pm
    Hi is it possible to retain the 3d positioning of layers when these layers are nested in a composition and that composition is brought into a main composition with a camera.
    For example ‘comp 1’ has 5 3d layers with text/shapes and all 5 layers are spread out on the z axis…..this is fine…I can zoom through 3d space using a camera and get a sense of depth/space.
    If I bring ‘comp 1’ into ‘comp 2’ and add a camera, after effects now only sees comp 1 as a flattened 2d layer inside of comp2. This happens regardless of whether I have the 3d layer activated on the comp1 layer.
    Any help would be great.
    Joey
    Joey Campbell replied 13 years ago 2 Members · 4 Replies
  • John Cuevas
    August 28, 2013 at 10:04 pm
    Turn on the continuous rasterization/collapse transformations button, it looks like a little sun.
    More help here: Render order and collapsing transformations
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Joey Campbell
    August 29, 2013 at 9:10 am
    Thanks Johnny – I had thought that button was only linked with vectors!
    I ahve a related question to do with 3rd party plugins.
    I have noticed it doesn’t seem to work for nested comps. containing Trapcode Form but does work for nested comps containing RedGiant Plane Space. Is this a known glitch/issue or is there a work around ?
    Joey
  • John Cuevas
    August 29, 2013 at 11:42 am
    Don’t have any answer other than they are two different plugins and perhaps handle z-space differently.
    I don’t have Plane Space, but none of the trapcode plugins can be used with collapse transformations(since they really aren’t 3D, but projected 3D). In the past when I have absolutely had to precomp a trapcode, I add a camera and use expressions to link it to a camera in the main comp.
    Thinkck.com
  • Joey Campbell
    August 29, 2013 at 7:26 pm
    Thanks for the info John
