Activity › Forums › Apple Final Cut Pro Legacy › retain timecode?
  • retain timecode?
    Posted by Cade Muhlig on May 17, 2007 at 3:29 am
    i shoot in hdv, and now i want to capture it in dvcprohd with my kona lhe card to edit. can you control the deck… batch capture… keep the timecode?
    i dont think you can, but maybe there is a way.
    Michael Gissing replied 19 years, 4 months ago 4 Members · 3 Replies
  • Shane Ross
    May 17, 2007 at 4:00 am
    RS-422 to the deck to control it…that also captures timecode. Sure…very possible. Wouldn’t recommend this option if you didn’t get time code. That is gold.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Jeremy Garchow
    May 17, 2007 at 4:03 am
    What are you capturing from? If using firewire, change the deck control to firewire, keep video/audio routed through the Kona and you should be good.
    Jeremy
  • Michael Gissing
    May 17, 2007 at 4:44 am
    I capture HDV from the Canon camera with HD SDI to the Blackmagic card and firewire control for time code/ machine control. I usually go straight to uncompressed HD as I am online conforming finished edits.
    The offline is done with firewire capture from the HDV camera/ deck as DV codec. Timecode is good both for offline and recapture
