Activity Forums Adobe Premiere Pro Retain original tapes timecode, JVC HD100 when captured?
  • Retain original tapes timecode, JVC HD100 when captured?
    Posted by Deleted User on January 15, 2007 at 2:13 am
    Hello,
    Does anyone know if its possible to retain the original tapes timecodes with my HDV footage, I captured to Vegas, Cineform, tried to Premiere pro with a lot of difficulty just capturing 2 secs as loosing connenection to the deck, and various other porblems.
    Using the tiemcode video filter in Prmeiere Pro i cant seem to get the original tape time codes, I plan to edit on Premiere Pro 2.0 but when I make an AAF or EDL no roginal time codes are here? Just 00:00:00:00 till the end of the captured clip then the next clip has the same timecode process.
    So looks like the clips I am captuing from HDV tape do not allow the tiomecode to be retained?
    If any one knows a way round or why this is not supported that would be great.
    Leo
    Deleted User replied 19 years, 4 months ago 2 Members · 2 Replies
  • Kevin Kefgen
    January 15, 2007 at 6:58 pm
    In the effects menu, there is a timecode effect. Apply it, using the option to use your own time code. Put in the first frame’s code, and it should work like a charm.
    I had to do this for ten tapes to dump to DVD for someone else to do an EDL. Worked great!
    Thanks for reading!
    Kevin kefgen
    Edit Guppy Post Production
    Las Vegas, NV
  • Deleted User
    January 15, 2007 at 8:29 pm
    Hello,
    I tried this as well as I used it before on projects, the timecode is on the JVCHD100u tapes and I see the timecode in Vegas when its captures and Cineform, but when the video clip is put into any of of Vegas, Premeire pro as a test the Timecode was blank with the effect and tried all the options, get time from clip, media, etc.
    So maybe it’s a camera fault perhaps or the way this format from the JVC is handled?
    Leo
