Activity › Forums › AJA Video Systems › retain hdcam captions?
  • retain hdcam captions?
    Posted by Jason Levy on November 25, 2010 at 3:06 pm
    Hi all.
    I need to insert a correction into an HDcam master. Typically we master onto DVCproHD so I’d be renting the HDcam deck and don’t know it well.
    The master is close captioned… is it possible to capture, correct and reinsert with the captured captions? If so what is the technique for retaining the captions?
    Card is a Kona LH.
    thanks,
    jason
    Jason Levy replied 15 years, 10 months ago 2 Members · 2 Replies
  • Chad Brewer
    November 28, 2010 at 2:11 am
    Jason,
    The Kona 3’s we have can capture VANC for 708 CC on capture. The closed captioning remains fine in Quicktime, but going back to a VTR via SDI doesn’t retain the CC. We’ve been up and down this every single way possible with all of our hardware. Retaining the VANC data between computers and VTR’s is a hard thing.
    In your circumstance, I think the only way to re-insert the CC on your insert edit is to use the FCP7 edit to tape with the CC file option which will require an .scc file of the that specific portion of the the closed captioning.
    Chad Brewer
    Senior Tape Operator/Engineer
    TeleVersions
  • Jason Levy
    November 28, 2010 at 2:47 pm
    Hi Chad,
    Thanks for that useful information. It’s appreciated.
    jason
