Activity Forums Adobe After Effects Resuming a render after rebooting
  • Resuming a render after rebooting
    Posted by Anthony Mckellin on December 15, 2008 at 10:34 pm
    Hi, I was wondering if it’s possible to pause an item in the render cue, and resume it after restarting the computer? I’ve got a large composition rendering that will take around 7 hours and I’m on a tight deadline. I’d like to do the trick that allows after effects to use more than 2 gigs of RAM and hopefully speed it up, but it requires a restart and the render’s already about a quarter through. Can anoyone help me?
    Pronil Halder replied 7 years, 1 month ago 3 Members · 2 Replies
  • Kevin Camp
    December 16, 2008 at 1:05 pm
    although i don’t think you’ll get a huge boost from the extra gig of ram that you’ll be able to allocate to ae, you should be able to cancel the render in the render queue and ae should add a new render to the queue that will start where the last one was ended (this will of course give you two separate media files, unless you are rendering to an image sequence)….
    if you do try this, i would take note of the frame that the first render was canceled on, then if ae doesn’t create a new queue, you can manually create a new queue taht starts where the last one finished.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Pronil Halder
    August 3, 2019 at 9:14 am
    You can put your pc in sleep mode instead of reboot. Check out this video tutorial which clearly shows how to do it properly https://www.youtube.com/watch?v=PrnjDxZE95A
