Activity › Forums › VEGAS Pro › Results of rendering 2 core versus 4 core
  • Results of rendering 2 core versus 4 core
    Posted by Melissa Brafoo on November 2, 2011 at 10:00 pm
    I know there has been other posts regarding the rendering speed improvements you get when you go with more cores, but here is another to encourage you to upgrade. 🙂
    I created 2 video clips, cut each to be 1 minute in length, set it up as a 2-camera workflow, made 5 shot changes (every 10 sec), each with 1 second cross-fades, and an intro and extro fade of 5 seconds.
    The render time with my old 2 core cpu was: 7 min, 33 sec
    I installed the 4 core cpu, and the time was: 3 min, 57 sec
    Which shows that, at least from 2 -> 4 cores, it scales very well, resulting in an x4 render time that is about 52% of the x2 render time.
    Looking at the Task Manager, the 4 core render shows all the cores about equally busy, with total overall CPU usage varying from 81%-96%.
    Further info:
    Windows 7, 32 bit installation, 3GB usable memory.
    x2 cpu: AMD Athlon II X2 250, 3.00 GHz
    x4 cpu: AMD Athlon II X4 645, 3.10 GHz
    AVCHD video inputs were from a Canon Vixia HF R100,
    60i, XP+ (12 Mb/s), both with audio tracks with some voice over. Render was to WMV, 1280×720, 29.97, 5 sec/keyframe, 90% sharpness.
    Dave Lozinski replied 14 years, 10 months ago 2 Members · 1 Reply
