Activity Forums Adobe After Effects Expressions restrict slider
  • Dan Ebberts
    May 28, 2009 at 1:59 pm
    Right click on the value, select Edit, and set the Slider Range? Or are you talking about something else?
    Dan
  • Alex Dinnin
    May 28, 2009 at 2:05 pm
    Hey Dan,
    thanks for the prompt reply..
    what I meant was when i drag on the number in the effects panel…
    it ignores the slider range.. and just flies from -99999 to 99999
    wondering if there was a way to stop that ??
    I’m not really using the slidey slider bar… “thats the technical term for them if you didn’t know” 🙂
    just dragging over the numbers !!
    thanks again
    Alex
  • Dan Ebberts
    May 28, 2009 at 2:32 pm
    The best I can think of is an expression like this:
    linear(value,1,100,1,100)
    It’s not ideal, but it might do what you want. The other possibility would be to hack the PresetEffects.xml file and hijack one of the presets to create a slider with a valid_min of 1 and a valid_max of 100;
    Dan
