Activity Forums Apple Final Cut Pro Legacy Restoring Archived AVC-HD project efficiently
  • Restoring Archived AVC-HD project efficiently
    Posted by Mark Laslo on October 21, 2010 at 1:35 pm
    Hi All,
    Sorry if this has been asked, I am not sure how to effectively search it in the forum.
    I am in the process of experimenting with archiving and restoring projects shot using AVC-HD. My strategy which has been suggested here is to archive by deleting all the ProRes files and just keeping the raw AVC files. This works fine, but in a lot of cases I transcode more of the clip that was originally needed. I am curious if there is a way to only restore the parts of the video clip that I used in the timeline to save myself restoration time. Example: I have a 10 minute interview that I only use 4 or 5 bites from. It would save me a lot of time to only retranscode those 5 bites as opposed to the entire interview.
    Any suggestions are greatly appreciated.
    Cheers,
    Mark
    Mark Laslo replied 15 years, 11 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    October 22, 2010 at 1:15 pm
    I don’t believe there’s any way to only “re transcode” only what’s contained in a sequence which started as a full transcode of the avchd material…
    Best to just keep the prores.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    DVD:https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Mark Laslo
    October 22, 2010 at 1:19 pm
    Thanks Jerry,
    Right now keeping the ProRes isn’t really an option. Budget is tight so getting additional drives is tough, being able to store a few extra projects on that drive can be quite helpful. I can wait for it to transcode again as I don’t often restore the projects and they’re all pretty short at this point in time.
    Mark
