Activity › Forums › Apple Final Cut Pro Legacy › Restored files lack .mov extension
  • Restored files lack .mov extension
    Posted by Bob Cole on May 15, 2010 at 3:51 pm
    Last year I backed up a 2007 project, media files and all. When I restored the media files they were listed as “Unix executable files,” having apparently lost their .mov extensions.
    (FWIW, here was the trip that these Quicktime files took: Tiger Mac Intel to PC hard drive to the LTO tape system on the PC; then back from LTO tape to PC to Snow Leopard Mac. I’m working on making the process cleaner, but it has worked perfectly before this episode.)
    I can right click on each media file, “Get Info,” and use “Name & Extension” to add .mov to each file -> in Final Cut Pro, Reconnect Media -> Success.
    But there are hundreds of files to add the extension.
    (1) is there a global way to add extensions to files in Snow Leopard?
    (2) where did I go wrong, so that the files lost their .mov extensions?
    Bob C
    Patrice Freymond replied 16 years, 4 months ago 4 Members · 7 Replies
  • 7 Replies
  • Arnie Schlissel
    May 15, 2010 at 4:13 pm
    You can use Automator to add the .mov extension back. It’s actually pretty easy, you need to input your files with “Get Specified Finder Items” or “Get Folder Contents”, then use “Rename Finder Items”. Set the rename to “Add Text” “After File Name”.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Michael Sacci
    May 15, 2010 at 5:02 pm
    I don’t use it but there is app called Automator (part of the OS software) that can record and playback most task. I don’t know how to get it to look into a folder and run the add.mov to all the files but it might be worth taking a chance.
    In the end adding the .mov can do pretty fast just by doing it with keyboard shortcuts.
    Select the file, hit return, down arrow, type or paste .mov, return again, use .mov
    down arrow to select the next file and repeat.
  • Bob Cole
    May 15, 2010 at 5:17 pm
    Thanks Arnie!
    A related question, that predates (but is very much part of) this situation:
    At some point in the rosy-colored past, when I used Reconnect Media/Reconnect All Files in Relative Path, FCP elegantly restored connections to many media files at once.
    For whatever reason, when I try that now (and for some months now) I only get the one file.
    I am using every variety of the parameters that I can think of:
    Matched Name and Reel Only – whether checkmarked or not.
    Locate or Search – either technique for locating the file.
    This is going to be a lot of work relinking all these files. Am I missing something?
    Thanks again for your help.
    Bob C
  • Bob Cole
    May 15, 2010 at 6:12 pm
    I forgot to say this explicitly – Arnie, your detailed explanation of Automator was very helpful and worked perfectly. Thanks again.
    BC
  • Bob Cole
    May 15, 2010 at 6:13 pm
    Thank you Michael. That’s very helpful, actually.
    You might want to check out Arnie’s Automator suggestion – it works beautifully for large collections of files.
    BC
  • Arnie Schlissel
    May 15, 2010 at 8:35 pm
    [Bob Cole] “At some point in the rosy-colored past, when I used Reconnect Media/Reconnect All Files in Relative Path, FCP elegantly restored connections to many media files at once.
    For whatever reason, when I try that now (and for some months now) I only get the one file. “
    I see that too, sometimes. Don’t know why it happens. I didn’t see it with FCP v5 or 6, but I see it with FCP v7.
    Arnie
  • Patrice Freymond
    May 16, 2010 at 2:14 pm
    Another opyion for tasks like these: use Name Changer. Lots of different features for flexible renaming.
    hope this helps
    P.
