Activity Forums Sony Cameras Restore media error EX1 MxR
  • Restore media error EX1 MxR
    Posted by Bob Mark on July 27, 2009 at 4:28 pm
    I have two MxR adapters and two new Transcend class six cards. They are being used by a friend. He sent me an email saying he keeps getting the restore media prompt. He says he has to shut down the EX1 to do this. Any idea why he keeps getting the error? I warned him about the record light going to green before recording again. Could it be a bad card? He says he has not lost any clips. Thanks.
    Lachlan Fletcher replied 16 years, 3 months ago 6 Members · 16 Replies
  • 16 Replies
  • Craig Seeman
    July 27, 2009 at 4:38 pm
    It could be he doesn’t understand about waiting until the light turns green again.
    It could be counterfeit cards.
    It could be the cards are too slow (bad cards).
  • Bob Mark
    July 27, 2009 at 4:42 pm
    Craig Seeman wrote:
    “It could be he doesn’t understand about waiting until the light turns green again.”
    Quite possible
    “It could be counterfeit cards.”
    They came from CompUSA.
    “It could be the cards are too slow (bad cards).”
    That’s possible. I just got them and have only done basic testing on them.
    He needs to use them tomorrow, so I’m nervous about that.
    Thanks.
    Bob
  • Craig Seeman
    July 27, 2009 at 7:59 pm
    One should thoroughly test BEFORE using especially if it’s a critical/paying work situation.[Bob Mark]
    “They came from CompUSA. “
    I don’t know about the sources of the post bankruptcy CompUSA.
    [Bob Mark] “He needs to use them tomorrow, so I’m nervous about that. “
    He needs to TEST them and KNOW how to use them by that time then.
  • Nigel Ellis
    July 27, 2009 at 8:56 pm
    It could be that he is shooting 720/60P or overcranking to something else. Need more info on what he is trying to do.
    Nigel Ellis
  • Craig Seeman
    July 27, 2009 at 9:26 pm
    720p60 wouldn’t have any impact all HQ is 35mbps VBR regardless of frame size or rate.
    Overcranking is another story. One should not overcrank with them as that can certainly result in Media Error issues although the exact frame rate point and duration can vary by card.
  • Chris Babbitt
    July 27, 2009 at 11:19 pm
    If you go to Transcend’s website, you can verify the legitimacy of your cards by submitting the serial numbers.
  • Bob Mark
    July 31, 2009 at 1:38 pm
    I did some tests yesterday. I was using MxR with Transcend 16GB class 6 cards. One of the cards had media needs to be restored errors about every fifth recording. I pulled the adapter and reseated the SDHC card and have had no errors since (knock on wood). Even when I had errors the clip was there.
    BTW, my record light goes to green after only 4-5 sec. with the Transcend card. My SxS go green in about 2-3 sec.
    Bob
  • George Dombrowski
    January 13, 2010 at 10:39 pm
    I just bought 2 transcend Class 6 16 gb cards and using them for the first time in e-film reader in the ex1 with firmware 1.11
    Every 2 to 3 minutes the error stops the recording. I did check and I do have authentic transcend chips. I got two e-film readers too and nothing is reliable except the Sony SxS 8gb cards.
    chec@cox.net
    What have the rest of you done? Will transcend replace cards with good stock?
  • Craig Seeman
    January 13, 2010 at 11:43 pm
    Don’t use Transcend. They’re unreliable from build to build.
    ATP ProMax, Sandisk Extreme (Class 10)
    Seem to be the reliable cards currently.
    I’m in the process of testing the Sandisk Extreme cards (16GB) and they’re rock solid. Two cards in camera, recorded two hours straight through without an issue.
  • George Dombrowski
    January 13, 2010 at 11:52 pm
    It’s such a let down. The Australian company, e-films, that makes the MxR card, endorses the Transcend cards as good. And their USA dealer in Boston sells the Transcend the same.
    Any chance that anyone has held Transcend responsible for delivering a true-Class 6 card.
