Activity Forums Web Design (WordPress, Joomla, etc.) Responsive Embed Video WordPress
  • Responsive Embed Video WordPress
    Posted by Patrick Mustain on January 21, 2015 at 9:00 pm
    Hullo!
    I’m not a programmer pr developer, I’m just trying to get some help with my portfolio site: https://patrickmustain.com/
    I’m using Hero theme, from Theme Trust, and it’s a responsive theme, at least on the home-porfolio page, and the projects page, and videos embedded from either youtube or vimeo resize just fine. Here’s an example: https://patrickmustain.com/project/move-over-kale
    But! On my “About” Page, I’ve embedded a video and it doesn’t resize: https://patrickmustain.com/about
    I’ve looked on other forums and found a number of suggestions with code included. I tried following the instructions from this post:
    https://www.smashingmagazine.com/2014/02/27/making-embedded-content-work-in-responsive-design/
    But apparently I’m missing something. The post above says:
    ” you need to add a containing wrapper around the iframe. Your markup would be as follows:”
    So this is what it looks like on my website:
    Then it recommends adding some code to the CSS style sheet. In the Appearance menu, I went to “Editor” which I’m pretty sure is the CSS stylesheet, and pasted the following code at the very bottom:
    .video-container {
    position: relative;
    padding-bottom: 56.25%;
    padding-top: 35px;
    height: 0;
    overflow: hidden;
    .video-container iframe {
    position: absolute;
    top:0;
    left: 0;
    width: 100%;
    height: 100%;
    There is clearly a step or process I’m missing. Does “adding” something to the CSS stylesheet involve more than simply pasting some code at the bottom?
    I could use some help, and thanks so much!
    Patrick
    Patrick Mustain replied 11 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
