Activity Forums Avid Media Composer Re:Sorenson Squeeze problem
  • Re:Sorenson Squeeze problem
    Posted by Richard Garry on June 23, 2008 at 8:45 am
    Hello,
    We’ve got 3 Avid MC’s with Mojos connected to a shared Unity, we export Quicktime Ref’s to a partition and from that burn MPEG’s using Squeeze. However, now 2 of the suites get an error message stating: “file not supported” when dragging in from that partition, if we drag the refs first to the desktop and drop into squeeze then it’s fine. Any advice would be appreciated?
    Thanks in advance.
    Otis F
    Patrick Forestell replied 18 years ago 2 Members · 1 Reply
  • Patrick Forestell
    September 3, 2008 at 2:16 pm
    I have a similiar problem, I make a QT ref file using AVID Newscutter, then make a DVD using Squeez 5 and althouhg I can burn a DVD using Vegas DVD Arch, I can no longer access that Aqueez reneder file by any other apllication, such as Vegas Pro 8 ! Thus if I ever have to edit those Aqueez renedrs I can not do so as I can’t get the Squeez MPEG2 file into any MPEG edit program. Patrick
    PS: If I use Vegqas Pro 8 to enoce compress a MPEG2 and then burn that file using DVD arch, then I can acess that resultant MPEG2 file in other Mpegs capable editors.
