Activity › Forums › Adobe After Effects › Resolve/Premiere Pro CC 14/AE Linked Comp Round Trip Workflow Q’s
  • Resolve/Premiere Pro CC 14/AE Linked Comp Round Trip Workflow Q’s
    Posted by Randy Rubin on September 24, 2014 at 6:02 pm
    Hi All,
    Posted this on the Adobe forum, but figured multiple opinions is never a bad thing!
    I started using Premiere Pro for a project I just wrapped editing. I switched from Avid because I knew I’d be doing a bunch of comping in AE. Here is what I’ve done so far:
    1. Resolve: BMCC/BMPCC Raw files converted to Proxy and exported AAF DNxHD 36 files (originally was going to use Avid)
    2. Premiere: Edit footage and during editing created numerous linked AE Comps.
    3. Premiere: Finished the cut and am now attempting to determine how to relink the AE comps to the RAW footage to grade and send back to Premiere/AE. I’ve used an XML to relink to source camera files in Resolve with no issue outside of some effects not supported and the AE Linked Comps.
    I understand this is going to be a bit of a manual process but here is what I’m thinking: log each clip used in AE manually, grade the footage in resolve, export as lossless a file as possible (DPX?) and use the ‘replace’ function in AE to replace the proxy files with the graded footage.
    Any tips on how to make this a bit smoother?
    Randy Rubin replied 12 years ago 51,219 Members · 3 Replies
  • Randy Rubin
    September 24, 2014 at 7:00 pm
    Edit is locked.
  • Randy Rubin
    September 24, 2014 at 7:46 pm
    Was there something in my workflow that suggested that it was not locked?
  • Randy Rubin
    September 25, 2014 at 7:45 pm
    Thanks, nope only a minute long video. I was going to upres some of the footage back to 2.5K for scaling but maybe that’ll throw off the effects – I’ll have to see.
    Is there a better workflow for future projects you could suggest?
    Appreciate the help.
