Activity Forums DaVinci Resolve Resolve/FinalCutPro color shift
  • Resolve/FinalCutPro color shift
    Posted by Mats Andersen on July 6, 2011 at 10:06 pm
    I have just finished a grade in Resolve.
    My source is ProRes 4444 – the setup is unscaled full range data.
    When I render this as ProRes 4444 it looks correct in Quicktime player, and when I reimport to Davinci –
    but when I import to Final Cut Pro 7 it looks milky with light blacks.
    It looks a bit like if I had switched to “normally scaled legal video” after finished grading in Davinci, I guess that Final Cut has problems displaying full range colors ?
    My setup and calibration is REC709.
    I prefere to use ProRes and to be able to make the master from Final Cut on this project.
    Any ideas how to work around this ?
    Fred Fleureau replied 15 years, 1 month ago 5 Members · 4 Replies
  • Roman Hankewycz
    July 7, 2011 at 4:07 am
    Sorry I don’t have any input on what might be causing this but I will say that I’ve gone a couple of prores4444 projects without this issue.
    I hate when people suggest this but make sure that all of your versions and updates are correct.
    roman hankewycz
    harbor film company // colorist
  • Sascha Haber
    July 7, 2011 at 6:39 am
    And dont trust FCP ever…ever ever ever ? EVER ! 😉
    Does it change when you press play ?
    Does it look different on your video monitoring ?
    Load it back into Resolve and compare there too.
    I bet its a FCP sequence setting.
    A slice of color…
    DaVinci 7.1.2 OSX 10.6.7
    MacPro 5.1 2x 2,4 24GB
    RAID0 8TB eSata 6TB
    GTX 285 / GT 120
    Extreme 3D+ WAVE
    http://www.saschahaber.com
  • Margus Voll
    July 7, 2011 at 6:42 am
    Prorez tends to make nifty gamma shifts from time to time.
    I specially remember this going to whiter or darker thing.
    Margus
    https://iconstudios.eu
  • Fred Fleureau
    July 7, 2011 at 1:21 pm
    make sure in your fcp prores sequence prefs that the gamma option is set to “none” ….
