Activity Forums DaVinci Resolve Resolve XML imported time-remapped clips issue
  • Resolve XML imported time-remapped clips issue
    Posted by Tomek Dyszkiewicz on October 14, 2015 at 4:08 pm
    Hi, I am editing in Premiere Pro and then export timelines via xml to Resolve for grading. The same problem always occurs when a project has time remapped clips – Resolve just messes with it making some lag just on speeded clips.
    How to make Resolve read xmls properly 1:1?
    Tomek Dyszkiewicz replied 10 years, 11 months ago 1 Member · 1 Reply
  • Tomek Dyszkiewicz
    October 16, 2015 at 7:22 pm
    A little update.
    I noticed the problem is hidden in Davinci Resolve the way it imports videoclips. I noticed that for example light strobe in certain clip occurs exactly in frame #3 in Premiere but in Resolve it takes place in #2, just like the first frame was cut off in Resolve. This way the last frame in Premiere is the last frame, but in Resolve the last frame-1 is the last but repeated twice.
    So my question is – WHY THE HELL RESOLVE makes that irritating one frame offset on EVERY clip of same camera?
    Just to mention – I have two cameras and one of them work perfectly, but the second one has offset. Both quicktime but I just found odd parameter in media info:
    “Format settings, ReFrames: 1 frame”
    “Format settings, ReFrames: 2 frames”
    Is it somehow related? Why does it work in Premiere and Resolve not?
