Activity Forums DaVinci Resolve Resolve suggested enhancements in node tree.
  • Resolve suggested enhancements in node tree.
    Posted by Ron Smith on August 17, 2013 at 5:15 pm
    Currently I use lots of node sometimes up to 20.
    Would it be possible to increase the density and width of the highlighted node on the screen.
    It would be great with a quick glance to see what node you are resting on,especially with many nodes and not always being right on top of display..
    It would also be great to have a simple symbol above nodes with windows and tracking engaged.
    Those are the two things that can cause problems when shots moves and with many nodes in the tree. Putting my cursor on each and every node to see what is active takes alot of time that can be better used elswhere.
    thks
    Jake Blackstone replied 13 years ago 2 Members · 1 Reply
  • Jake Blackstone
    August 19, 2013 at 4:56 am
    Using 20 nodes on regular basis is not normal. You should look into using less:-)
    But if you feel, that using so many nodes is necessary, then take your time and name your nodes- skin, sky, vignette ets. That’s why this feature is there…
